Mk4 Ls400 Play In Steering
There's always been a little bit of play in the steering on this car, not an issue while driving although it does produce some slightly uncomfortable knocks now and again. I've pretty much just ignored it as it hasn't ever gotten worse. I presumed it was on the steering column somewhere, in a place difficult to get to.
However, today I discovered that the play is almost certainly in the universal joint just above the driver's pedals, where the steering column pokes through the carpet. I can put my fingers around it and feel it moving as I twitch the wheel back and forth. So obviously, now I know exactly where it is, I want to fix it. Has anyone else had such an issue?
And while I'm on the subject, I find it strange that there's no bit of plastic covering the top of the pedals. Am I missing a bit of trim?
