HI
My rear screen will not de-mist, the mirrors work fine but not the rear screen. is there a fuse or relay and where are they? it's a 1997 'P' plate car..
many thanks james
According to the wiring diagram the relay powers both the mirrors and rear screen so if the mirrors are working so is the relay.
This would suggest either a problem with the wiring from the relay to the rear demister or the demister element itself.
There is a choke coil mounted in the left rear of the boot which the 12 volt supply passes through before it reaches the demister element.
Another possibility is the earth connection on the demister is not connected.
