Maintenance Intervals Checklist
For those of us who service their own cars, I'm trying to gather the intervals for maintaining different things on the IS250. I've listed the ones I know, and the ones I dont know the intervals for too so someone kind advise. If i've missed anything too, it will be nice to add to the list so other IS250 members can use it as a checklist.
  • The Usual Oil and Filter Changes every 10k or 12months
  • Air and Pollen filter (I change them every year as they are cheap anyway)
  • Spark Plugs every 60k Miles
  • Coolant after 100k thereafter every 50k miles
  • Rear differential fluid - ??? not sure at what intervals this should be done
  • Front differential fluid - ??? not sure at what intervals this should be done
  • Brake fluid change - ??? not sure at what intervals this should be done
  • Air conditioning clean and recharge - ??? not sure at what intervals this should be done
Have I missed anything?
These are factory recommended service intervals up to 105k
65k
Replace engine oil / oil filter
Visually inspect the brake pads and discs
Road test the vehicle
70k
Replace the engine oil / oil filter
Measure the front brake pads and disc
Visually inspect the brake pads / discs
75k
Replacve the cabin filter
Inspect the axle shaft boots
Inspect the ball joints and covers
Inspect the body
Inspect brake lines and hoses
Inspect the drive belts
Inspect engine coolant
Inspect the exhaust pipes and mountings
Inspect rack and pinion steering assembly
Inspect rear diff oil
Inspect steering linkage and boots
Visually inspect brake pads and discs
Road test vehicle
80k
Measurer thickness of front pads and discs
Road test vehicle
85k
90k
Replace the cabin filter
Replace the brake fluid
Replace engine air filter
Measure brake pad and disc thickness
Inspect axle shaft boots
Inspect ball joints and covers
Inspect body
Inspect drive belts
Inspect exhaust pipes and mountings
Inspect fuel lines and connections / fuel tank band and fuel tank vapour vent system hoses
Inspect fuel tank cap gasket
Inspect rear dif oil
Inspect transmission for signs of leakage
95k
100k
Replace the engine coolant
Measure the thickness of the front brake pads and discs
105k
Replace/clean the cabin filter
Inspect the ball joints and dust covers
Inspect the body
Inspect the brake lines and hoses
Inspect the rack and pinion steering assembly
Inspect the rear dif oil
Road test vehicle
It would be good for someone to post the location of each item on the schedule to check (with pictures) and possibly what problems to look for - might get round to this when I have time in the summer...
Hope this covers everything
I had this from Lexus in the USA
I can see the sense in changing the oil every 6 months - depends on how many miles doing and how you are driving it - the checks - brakes / discs etc I am guessing is something they do but no hassle to give them a quick look.
Whats missing from this is the spark plug intervals and the caliper slider pin checks...
IS200 Newbie, yes the american service manuals for the IS250 have a less miles interval but in Europe the service manual says 10k Miles. Which i followed as per manufacturers requirements until 150k, after that started doing my own service and i think i'll do oil changes around every 7k miles instead of 10k.
Err... what about transmission oil? :zee:
The transmission is a sealed unit, the only time ATF needs changing is if you have to drain fluid to do some work like replace solenoids etc. Even that will not replace the entire ATF only a small portion of it.
From the Lexus European service manual.
Spark plug replacement - every 60k. (see note)
Brake fluid - recommended interval is 2 years.
Trans fluid - Nomal use, no scheduled maintenance. Severe usage (e.g. urban driving, towing, mountainous driving) replace every 6 years.
Diff oil - Replace every 4 years
note - I changed mine at 70k and they showed very little wear, I'd suggest 100k or 120k as a reasonable interval, given the high cost of the plugs, risk of damage to the alloy head, difficulty of the job and need for replacing numerous gaskets as part of disassembly.
  • 6 years later...
Sorry for digging this out, but is it not rather:
Lexus Europe: 10.000km
vs
Lexus USA: 5,000 mls
Would make sense; or it could be we use here in Europe a better quality of life juice for the engine.
I change mine at 8,000km. Even if the oil is good quality, the condition of the car, as well as how you drive it will have different effects on it.
Regardless, no mechanical component has broken down due to frequent oil changes, so its better to change it earlier rather than later.
I did my oil change in December when I got the car and already nearing the 6000mls 😂
Did set the oil and oilfilter service thing in the BC.
Despite working from home, I drive on average 1000mls a month... back in the days when I commuted to work I was between 2500 and 3000mls a month 🤪
