Hi all, anybody got any tips on headlight removal, does the bumper have to come off? and is the headlight cleaner fitted to the bottom of the unit ? Any help would be appreciated :whistling:
Dave
I have just replaced my headlights and I can say the four nuts you get to after pulling back the wheel arch mud guards are not easy to get to. I saw this video on utube but it doesnt show the washer removal, they just pull towards you then you spring the clip out, you can't miss it, very easy.
When you pull the washer out there is a flat spring clip you need to pull up! its there believe me. I have just taken a picture of mine its attached.My finger is pointing to it.
post-34047-0-81511600-1406924101_thumb.j
arrgh!!!! the clip is missing on mine, but it still will not come off, is it tight after you prise the top and bottom tabs apart ? ive a feeling its glued on :megaangry:
