Eyelids
Gus
Hi Gus,
I undertand that you are unhappy, but please come to me first, since I may be able to solve this issue. The damage was likely caused during the mailing.
Many of the LOC members received the eyelids in good shape, and although I understand that you are unhappy, this mishap is a case of bad luck during the mailing.
Btw, I send you a pm.
Tape
- The ones with the tape were sent straight from me, as I wanted to offer you more convenience. Please note that you have to clean both the eyelid back and the headlight area as good as possible, otherwise the tape may loose it efficiency.
Painted eyelids
- These were sent directly from the supplier, who also did the painting (and also did not have any tape).
In addition to the tape, you can also use some silicon glue to stick the eyelids.
