Hi
I'm new to Gs300 after having ls400 for ages and wonder if anyone can help. It's a 2005 new shape and it's a lovely car. But today the low tire thing came up on display, so if I put air In it does it reset itself or do I have to reset it and if so, how do I reset it.
Thanks in advance
Thanks for that, I do know there is a button somewhere around there so ill have a look for that, but I've just put air in the tires and it seems to have done the job
  • 4 weeks later...
I've got a GS300 2005; Here's what I do: Inflate all tyres to correct pressure, then turn on ignition and start the car. Leave the engine running and sitting in the driver's seat put your right hand under the dashboard just to the right of your right knee. Lean forward and feel around and you'll locate the little black button. Press the button in and keep it pressed in for about five seconds until you hear a beep and the display shows "tyre pressure initialized". The system will have recorded the current tyre pressures and will subsequently warn you via the display if the tyre pressure on one or more tyres drops below about 15% of the recorded pressure. This procedure only works if the engine is running when you press and hold the black button. I've found the system works very accurately.
Cheers
Mickey
