Headlight Washers
On my last is200 that I had, the headlight washers must not have been used for a long time and when I tried them they opened from the bumper but squirted out a goo like substance all over the bonnet. A few rude jokes were cracked by my mates :shutit: but after a while the goo cleared and just water came out.
I think it was just some washer jet fluid that had started to go a bit solid over time.
If the turning the headlights on doesn't work then I would try fuses etc first but also disconnect the water hose somewhere and check for blockages.
You should also hear the water pump buzzing from outside the car if they are working. ;)
