Coolant Level Check
this may sound completely daft and i may well be loosing my marbles, but where is the coolant level reservoir to check the amount of coolant in the system??
i've looked over the engine bay and can't find it. checked the manual and the pic in there is clear as mud, but i get the general location but i swear i can't see it!!
any help please guys??
Hi Probley been said before but why do i have red coolant coming out of the filler cap...the one on the left hand side of the radiator ( with the pipe coming out of it ) looking at it face on at the top.? ive had a look and all it is is a plastic cap with no rubber washer inside.should there be one to stop it leaking?
thanx.
sorted now!! cheers chris.
i was sort of going mad. where it is was a bit harder to see with the s/c unit being there. but found it in the end!!lol
cheers again chris. :blush:
rob
Anytime matey, will have to pop over again mate as not been your way for a while :D
rob
do it mate!! just drop me a text and i'll let u know if i'm about etc :D :D
rob
OK matey will do :D
:offtopic: did you ever get your other halfs mini sorted mate with its running?? :unsure:
rob
OK matey will do :D
yes mate, sorted it myself. needed new plugs, the old one's were blackened something chronic!!
i'm normally around at mine most weekends and if im not here then i'll be in rugeley so can meet up at either i guess :D
Thats good matey i did say the plugs when you asked about it before as mine used to eat them for some reason :D
uea, and as they were easiest to check thats what i went for 1st.lol.
she now needs new rear discs and pads......women eh?? :ohmy::lol::whistling:
:lol: She should just give it to me mate i'll sort it out :whistling:
she's thinking about getting rid as it happens mate.
ur more than welcome to have a look at it sometime.....
thanx.
more than likely the reservoir is over filled
thanx.
Hi mat thanx for the reply...well when the car is cold and on level ground the coolant level is about 3/4 full on the radiator level and when its up to temperature the level goes to the full mark...its not alot of coolant coming out just dont know why it does it...i thought that it would just go out the pipe and wasnt sure if it was meant to have some sort of rubber washer under the cap...
