Just completed my custom IS-F grille for my IS250.
Note: The IS-F grille emblem is much wider than the f-sport grille emblem. Its more oval shaped.
Heres what i did:
  • * Trimmed the IS-F grille and made it fit inside the OEM chrome bezel of my IS250.
  • * Did some plastic welding and bonded the two trims together with heavy duty polymer bonding glue from the rear side.
  • * Sealed all gaps from rear side in preparation to pour liquid plastic from front side (hence sealing it from behind so the liquid plastic doesnt leak out)
  • * Poured the 2 part liquid plastic polyurethane so that it seals all gaps and provides extra bonding.
  • * Once liquid plastic set and became plastic, covered up with thin layer of plastic filler
  • * Sanded filler down and once everything was ok proceeded with wet sanding and paint prep
  • * Painted and clearcoated
I'm quite happy with the result and I think the difference is very subtle but it makes a huge difference
here are the photos. let me know what you all think
Completed and Installed Photos:
DIY Photos:
  • 4 weeks later...
