SatNav help please
I am off on a bit of a round trip tomorrow up to Lincolnshire and have been setting up my destination points on the SatNav.
I have set each of my ports of call by using the postcode page and have set them into the memory section so that they can quickly be recalled.  However, I don't seem to have been given the option/s to enter either a house number or a bit of descriptive text such as 'Bob and Betty'.
Before I had my Lexus I always use a Garmin unit and, when I turned into the road that I wanted, a voice would say "You have arrived at Bob and Betty on the left"
Is this sort of entry not possible with the Lexus.  When I open up my memory points page, there is a whole list of postcodes but I would like to be able to identify them, rather than rely on my memory.
I haven't spotted anything yet but I am going through the manual again now to see if I can spot anything second time around.
Thanks for any help that may be forthcoming.
Have you got these registered in the memory or have you just searched for postcodes? If you haven't registered them in the memory then go:
menu
memory
register
previous
pick the the one you've found before and you can rename from there.
if they're already in the memory then choose edit instead of register
I agree it's easy to do, as above go into the memory, edit and simply rename them. The trick when renaming is to rename them in the same way , i.e. Bob & Betty or BOB & BETTY, otherwise it looks a right mess. To me anyway [emoji846]
Sent from my iPad using Tapatalk
