Help with Injector seals
Philroy
Hi All,
My car was diagnosed with an injector seal leak on cylinder 2 and a suspected compression leak. This was diagnosed by the AA and confirmed by JEM Car of Colindale. They have recommended a main dealer for the fix.
Can someone please recommend a good independent to sort this out please?.....or any suggestions.
Please see attachment
Li.
Do you have any diesel specialists nearby?
They'll be much more knowledgeable and have many more unique tools than a dealer/garage.
Changing an injector is pretty straightword on the 2.2d engine, unless it's been leaking for a while and coked up. Should be 30 mins to an hour if straightfoward. Getting the seal out may be trickier
