Hi All
This may be handy if you need to top us on engine oil - ECP have 50% off using code FLASH50 - This will only work for engine oil so don't add anything else in the basket. For anything else use END35 for 35% off.
I have however found something strange and you guys may have noticed the same with ECP - Every time they have 50% off code the price of the item seems to be up by £2 or £3 pounds, sometimes more. For example 2 weeks ago the Castrol A5 (5W30) (Product Code: 521773421) was £20 after 50% off now the price is £46.99 so will be £23.50 for the 4ltr.
Good luck!
