2009 is220d non starter (imobiliser fault)
ceircymru
Hi, has anyone got any information on the following fault code B2799?
Fault won't clear and car refuses to start. I've also been trying to locate the immobiliser control nodule but no luck.
Any information appreciated, thanks
Do you have both keys and are they the originals?
From a quick Google search:-
B2799 is a fault that appears when the engine immobilizer doesn't read the transponder key. This means the key used is not programmed or the key has lost the code in it thus not being recognized by the system(Most time these are keys that are cut after loss of the original key)
