spacenase
12v Battery Maintenance
Has anyone got any suggestions on how to maintain the 12v Battery in the car whilst travel is so limited? I've heard of hybrid car owners having difficulty with their 12v Battery running down when they only do very short journeys because it doesn't get a chance to recharge properly, even more so than in non-hybrid vehicle.
Is it safe to use a trickle charger, or are there any other techniques we can use?
Park the car, make sure all interior lights are switched off including the courtesy, boot and glove box. Walk away and don't worry.
A trickle charger is fine, or a solar panel charger like these will work too.
Alternatively, just sit in the car and run it for a few minutes every two or three days, or go to the food shop in it.
I’ve never found a solar charger that works. Maybe it would parked outside in Spain but not in England and certainly not if parked in a garage.  You can use a CTEK Battery charger and leave it permanently connected.  After charging it will go into a maintenance mode where it will cycle the voltage to keep it healthy.
Thanks all, I'll see how it goes over the next couple of weeks and get a trickle charger if it struggles.
In the fuse box under the bonnet. Use the jump start terminals.
