RX300 2004 air suspension conversion to coil advice
I recall quite a few related posts on this RX forum.
A quick search will probably tell you what you need...
e.g. I searched on:   air  suspension  this-forum
Good luck.
30 minutes ago, TR7 said:
Does anybody know where i can get the conversion kit at a reasonable price.
Any fitting problems?
Just over two weeks ago I ditched the air setup on my LS430 and I wish I had done it ages ago.  A fairly easy job, I imagine the RX is fairly straightforward. A 40amp fuse pulled which eliminates any warning lights.  The only thing I would say is avoid getting really cheap ones.  It may be worth trying Rockauto or Strutmasters in the US, I went for the latter.  I witnessed a successful RX conversion in Brighton a couple of years ago!
