completed intake
Having custom intake made tomorrow for supercharger, using 3" stainless pipe leading from front left straight into compressor. Putting a K&N racing filtercharger filter on the front, the position should let in loads more cold air than the front scoop. Hopefully it will make a nice difference to engine response.
i think you need to move the filter,nearer and behind the headlight.............
at the moment its sitting face into the flow,and in the flow of the hot air from the radiator and fans.................
i also think a larger surface area/vector type filter would be of a greater benifit.....
but it does look good
Agreed!!...........plus the heat soak to the metal intake pipe being so close the exhaust manifold must also cost a fair amount of power. Perhaps re routing the intake pipe or at the very least some decent lagging should be beneficial. Also a heat shield to separate the radiator from the filter would be nice. Gotta try and keep things cooooooooool.
Mark :)
Mark :)
agreed.......and a cold air feed in would help alot.......even using a filter like the new pipercross one which is encased in its own cold air feed.....would bring some good gains,but as mark said the heat sink .....will be terrible at the mo.............that is what i think the biggest BHP killer is at the mo with the is200,the heat soak into the airbox is terrible,and the intercooler is way to small to handle it.............plus the return to the engine from the intercooler get to much heat soak from the radiator..............
these are things im looking at at the moment
mat:smug:
the old air box has been cut to fit, it also directs cold air down on to manifold, heat wrap is on order and so is heat sheild that will aslo send directed air in to filter.
Thermolastic Foil tape,3 layers deep, with thermalastic adhesive tape, will keep it cool, will be on by weekend.
Directional airflow head sheild also for front comming very soon. The main point is that the sensor works and No engine management lights come on, ( this seems to be a mojor problem in the states).
It will all be completed shortly. The intake for compressor is that close to the manifold and you cant come over the top as it will probably cause problems with the bonnet closing.
Cooler than John Travolta wearin shades on planet shade, on King shades national shade day
:cool:
The intake keeps the supercharger on the boil longer, the revs dont drop so quickly, previous 0-60 in cold was actually 6.7-6.9,
tonight in warm weather bang on 6.0 seconds. Aslo mid range seems to be more potent. Made make shift heat sheild also directs more cold air onto filter. Sounds awsome and has improved things:cool:
Old 0-60 was 6.5-6.7.
With new intake 6.0 possibly 5.97, intake keeps revs higher they do not drop so quickly between gearchange.
Silicon pipe being custom made to move filter across slightly. Heat insulation going on intake pipe tomorrow, insulated heat sheild that also directs cold air going in tomorrow.
Will post pics when complete.
Hi Vic,
the revs dont drop as quickly, old 0-60 was about 6.7 -6.9
New one on a warm night, on a bend. 0-60 = 6.0 secondsit may be a tenth under 6 seconds. The sound is awesome. It has gone back being hairy scary like when I first had compressor fitted. The filter will be improved more soon, custom silicone pipe being made to bring filter into airflow more. Some Very special insulation heat reflection stuff going on pipe and head shiled bieng made that also directs all cold air into filter.
