Grey One 50 Posted December 29, 2020 Share Posted December 29, 2020 I was looking for some Oz Racing alloys in the UK for the ISF, but couldn’t find any as a straight swap. Has anyone here got any experience of them and what sizes/specs on wheels needed? Thanks Quote Link to post Share on other sites
hockeyedwards 242 Posted December 29, 2020 Share Posted December 29, 2020 I used 'wheelbasealloys' for my LS and honestly couldn't fault the service and the wheel spec came perfect. Do you want 19s or 20s? Just checked pre-mentioned website and they have some OZ wheels suitable for the ISF 🙂 ISF standard wheels PCD 5X114.3 Front 19x8, Rear 19x8.5 or 9 (can't remember) Think std offset is 45 Maybe someone in the know can confirm or update that... but you can just adjust the offset accordingly if you go for wider wheels and if you decide to go for 20's, make sure you get a correct tyre size so the speedo doesn't have any large miscalculation (hard to do if you're sensible). Happy hunting 😄 Quote Link to post Share on other sites
hockeyedwards 242 Posted December 29, 2020 Share Posted December 29, 2020 2 minutes ago, hockeyedwards said: Think std offset is 45 That's front, think rear is 55? Quote Link to post Share on other sites
hockeyedwards 242 Posted December 29, 2020 Share Posted December 29, 2020 Last attempt...haha! https://www.wheel-size.com/size/lexus/is-f/2012/ Quote Link to post Share on other sites
Grey One 50 Posted December 29, 2020 Author Share Posted December 29, 2020 Thanks - I actually already saw this, couldn’t see necessary info for Oz wheels when looking at stockists, thus my original question. cheers Quote Link to post Share on other sites
Grey One 50 Posted December 29, 2020 Author Share Posted December 29, 2020 16 minutes ago, hockeyedwards said: I used 'wheelbasealloys' for my LS and honestly couldn't fault the service and the wheel spec came perfect. Do you want 19s or 20s? Just checked pre-mentioned website and they have some OZ wheels suitable for the ISF 🙂 ISF standard wheels PCD 5X114.3 Front 19x8, Rear 19x8.5 or 9 (can't remember) Think std offset is 45 Maybe someone in the know can confirm or update that... but you can just adjust the offset accordingly if you go for wider wheels and if you decide to go for 20's, make sure you get a correct tyre size so the speedo doesn't have any large miscalculation (hard to do if you're sensible). Happy hunting 😄 Thanks - I will take a look. Not sure on stock set-up of 19s & 20s, or 20s all round. Any negatives with all 20s? Quote Link to post Share on other sites
hockeyedwards 242 Posted December 29, 2020 Share Posted December 29, 2020 1 hour ago, Grey One said: Any negatives with all 20s? Just the usual stuff, bumpier ride due to decreased tyre profile, more so to do with width changes, check clearance of fronts when full locking and on some designs making sure you can clear front calipers if dished wheels are your thing. Wheelbasealloys allows you to enter all your car info, i.e 2012 Lexus ISF and it should throw up all wheels it can get fitment for and then you can narrow the search with filters, such as OZ as the brand. When you go to order they will double check all your call details before sending the wheels to varify fitment. Any particular wheel in mind, just being nosey 😛 Quote Link to post Share on other sites
Killysprint 144 Posted December 29, 2020 Share Posted December 29, 2020 Ran 10x19 et38 linea corse lc818 all square set up with 255/35 19 winters on my ISF. No rubbing, catching or problems with wheel arches still have them - wondering if they’ll fit the GSF.... Quote Link to post Share on other sites
hockeyedwards 242 Posted December 30, 2020 Share Posted December 30, 2020 13 hours ago, Killysprint said: wondering if they’ll fit the GSF... quite similar style to the stock rim, would you keep silver or colour change? Quote Link to post Share on other sites
Grey One 50 Posted December 30, 2020 Author Share Posted December 30, 2020 Was thinking of these in matt or silk black https://www.ozracing.com/alloy-wheels/oz-racing/i-tech/hypergt-hlt Quote Link to post Share on other sites
Killysprint 144 Posted December 30, 2020 Share Posted December 30, 2020 1 hour ago, hockeyedwards said: quite similar style to the stock rim, would you keep silver or colour change? Just as they are. The change would be to benefit on the winter tyres. But as we can’t go anywhere, (and likely to get worse from tonight) don’t think I’m going to bother Quote Link to post Share on other sites
hockeyedwards 242 Posted December 30, 2020 Share Posted December 30, 2020 23 minutes ago, Killysprint said: Just as they are. The change would be to benefit on the winter tyres. But as we can’t go anywhere, (and likely to get worse from tonight) don’t think I’m going to bother Yuppp, wafts around the block only it would seem 😔 Quote Link to post Share on other sites
Twellsie 302 Posted December 30, 2020 Share Posted December 30, 2020 i run 8.5 x 19 et53 front and 9.5 et38 rear, gives a nice flush look and no issues with rubbing Quote Link to post Share on other sites
NothernDan 966 Posted January 11 Share Posted January 11 On 12/29/2020 at 1:06 PM, Grey One said: I was looking for some Oz Racing alloys in the UK for the ISF, but couldn’t find any as a straight swap. Has anyone here got any experience of them and what sizes/specs on wheels needed? Thanks @Grey One, check out my wheels currently for sale, just posted a new thread. Quote Link to post Share on other sites
