23 hours ago, Riccccccardo said:
But where I’m confused you wouldn’t put yr cold air on in say winter time and how often are you supposed to put it on for?
It's only confusing when it's solely referred to as air conditioning, which is used for cooling, instead of climate control, which uses air con to cool and the heater to heat, as required.
I have mine on permanently, using the temperature controls when needed, and leave the system to do its thing.
I've received that recommendation many, many times over the years, for having the system constantly active maintains and lubricates the system seals most effectively.
On 5/27/2023 at 7:53 PM, Riccccccardo said:
Considering for this years to do list at next service possible coolant change and I think my front headlights need polishing as noticed a bit foggy on purchase Lexus quoted £99.
Press the EXPAND BUTTON to see what they looked like before clean up 👆🏾
New issue today my #WINDOW did not want to close rear drivers window I put down while driving when I parked up I pressed the door button to put it back up closed. It moved up near to closed then went back down again (refusing to close fully) I was very worried. It kept doing this with the door control so I tried the actual rear door button to close it and it did the same thing going up not closing fully then moving back down again remaining open. I then turned off the car and tried to see if I could close it with the car off and key thob control only nope did not work and did the same as above going up then back down again. Total attempts so far five to close window. On final attempt again using key thob I inched the window up slowly bit by bit to the top where it now appears to be closed. I’m thinking a computer glitch as it’s never done this before or if this is a longer term problem? will be stressful not being able to close the window if this continues and also the cost of fixing will pee me off. I’ll repost this in other rooms if I see one about this issue.
I think that the window runners need a little lube as it sounds like the window is sticking near the top & this can produce the issue you have.
A little Silicon spray into the runners each side & the top.
Even better, try PTFE powder (Amazon) an extremely fine powder, (basically Teflon), it won't attract dirt as a silicone liquid spray.   (also great for all plastic<>plastic rubbing surfaces, internal car trim squeaks) and clothes zips, curtain tracks etc
Edited by Illogan
Spolling mistooks
@Vfr #vfr @iiiogan #iiiogan I’ve just got back into the car today and everything working normal again. Hope was just a glitch.
I do tend to drive with the rear window behind the driver a little or half open for various reasons the majority of the time cool done car, de steam windows, when I want some cool outside air etc… for last two years owning the car. I think once or twice my car got splashed with other cars and large puddles whilst I was driving as well maybe? As well as light rain may go inside sometimes but I figure it can handle light rain right? I hope there’s no debris inside it even if there was I’m not skilled enough to take a Lexus door apart and put back together.
I hope you right it’s just sticking. Yeah I’m guessing dirt would stick to silicone so powder option sounds better I guess.
thanks for input lads.
The car is sensing that the physical resistance of the window is greater than normal, as if something being in its way, and therefore the anti jam safety feature is kicking in.
As has been said, clean/lube the edges of the glass and runners. If you still have a problem then disconnect the Battery for 30 seconds and then perform window initialisation which will make the vehicle learn the resistance for auto operation to function.
  • 3 months later...
Hi guys I’m very confused for years I’ve told people my cars 5.9 seconds 0-60 mph using most websites (and autotrader site) but I was on a random Lexus website recently and it states speed is 5.2 seconds 0-60mph. What speed are we all going with? I’m aware I think the newer year models mite be slower due to eco regulation constraints.
I think its 5.2 if you turn the electronics off and how how to pull off manually extremely well.
You lose a bit with the electronics on as they are a bit overly paranoid and limit the power more
than is needed at lower speeds.
Looking into this, the 5.2 sec time was claimed by Lexus in USA at launch for the phase 3 car. It is a 0-60 time, European times are 0-100kph so 0-62mph. Some American testers use a rolling start, which improves times.
https://en.wikipedia.org/wiki/Rollout_(drag_racing)#:~:text=For the published 0 to,the initial standing start position.
I couldn’t see any testers who had equalled or improved the 5.2 time.
to get the best time I believe you need to fully charge the traction Battery.
New issue which is very annoying and frustrating I’ve been quoted by one body shop around £250 I know it’s age related/wear and tear as my cars 2012. The boot rear wing lacquer is starting to peel off.
Hi should I be worried first time in four years my car wouldn’t start.
It only started after several attempts of me pressing the car on and off with the power button and brake pedal. Re the pictures does these words PARKING BRAKE INOPERABLE and CHECK AHB SYSTEM warning light was on when it wouldn’t start but they gone now the cars started and working.
I last fitted a new car Battery I think four years ago?
On 4/30/2024 at 2:48 PM, Riccccccardo said:
 Lexus receptionist told me 12 volt battery they fitted lasts 2-3 years I changed it beginning of 2021.
What utter nonsense. In the category of 'they'll tell you owt'.
My Battery is coming up to 10 years old. A Yuasa Battery (if that's what it is) should last for more than 6 years at least.
Hopefully it's a one-time glitch.
My battery is coming up to 10 years old. A Yuasa battery (if that's what it is) should last for more than 6 years at least.
Hi
Hi good news went to start the car today it started first time no issues after letting it sit for a day. So maybe that other day not starting only after several attempts issue was just some kind of one off computer glitches that anyone that’s got a computer knows happens every now and again. 😅
Possible you just ran the 12V down rather than anything wrong with it.
Because all the 12V has to do is start the computer and then open the relays to the main hybrid Battery, if its basically flat it may
actually still manage to start the car.
Had this a few times on my last 12V Battery when it was, well working but it had basically no capacity left after 15 years so was very
easy to run it flat if you left it on without the engine running for any period of time at all.
Because all the 12V has to do is start the computer and then open the relays to the main hybrid battery, if its basically flat it may
Had this a few times on my last 12V battery when it was, well working but it had basically no capacity left after 15 years so was very
Ops looks like I spoke to soon it didn’t start first time again today but eventually started after 5 minutes I’ve definitely got a problem somewhere. Gonna have to get someone at some point to diagnose it and it’s annoying happened at the end of my annual leave.
I’m still using Lexus Sidcup as I haven’t found a top quality inpendent Toyota/lexus garage yet. I’m from Gravesend area sides.
have no idea when I’ll have the time for this annoyance.
the 12 volt appears ok and the hybrid Battery seems ok like it charging ok.
but I’ll lean eye on the hybrid Battery could be suspect maybe.
I'm puzzled now. When you say it doesn't start, what exactly do you mean?
Normally you press the start button, the dash lights up and the system check runs. The engine doesn't start at this point. Then you press the accelerator pedal and drive away under electric power and it's likely the engine starts after you've driven a few yards.
At what point is the engine not starting? It shouldn't until you've moved some distance, depending on the state of charge of the hybrid Battery.
