Hey all, I’m new on this forum but hopefully someone can help me.
My steering wheel has some slack (vertically) as I can move the wheel up and down without using the adjuster.
The adjuster works as it should but the slack is driving me mad.
I took the cowl off today and had a look but I couldn’t see anything obvious, everything seemed to be in order.
I’m totally stuck so any help would be greatly appreciated.
Thanks,
Ross
11 minutes ago, steve2006 said:
Hi Ross and welcome to the LOC.
For some reason I can’t see your video.
The tilt slider assembly is shown below, I would recheck it is fully secured.
Thanks for the diagram, I’ll check it all out again tomorrow but from that it was pn 45709 that was sliding up and down as it lifted and lowered the wheel.
is there a way it could have worked itself loose?
A bit more info 😀
45709 SLIDER SUB-ASSY, TILT STEERING
45709-30030   1 $260.47
45709A BUSH(FOR TILT STEERING SLIDER)
90389-08133   4 $2.89
45798 CLAMP, STEERING INTERMEDIATE SHAFT, RH
45798-30010   1 $4.82
45810 GEAR ASSY, TILT STEERING, W/MOTOR
45810-30140   1 $893.69
45815 SHIM, TILT STEERING SUPPORT
45815-30020 厚さ=0.7 2 $1.58
45855 BOLT, TILT STEERING, NO.1
45855-30010 外径=8
