2011 RX450h Rear wiper blade
1 hour ago, steve2006 said:
Here are the Lexus part numbers if it helps, dealers supply the rubber only so slide out the old one and in with the new one.
Hi Steve,
do you also have the number for the rubber to the CT200h 20cm I think?
On 6/24/2022 at 5:49 PM, Tezza 2 said:
ok thanks I'll try that.  Seems odd that Bosch don't make one, it must be an odd fitting or something.
It should just be the standard Denso fitting. Not sure why they don't list it. Not sure about Bosch aftermarket ones but Autodoc.co.uk list the OEM one, or directly from Lexus on their official eBay store:
https://www.ebay.co.uk/itm/253755744919
or Lexus Parts Direct.
On other makes of cars that I have owned that have a rear wiper I would keep one of the fronts when changing them to use the rubber for the rear, I used to remove the rear rubber & old front then cut to that down to suit.
Now have a spare for the RX as a new set just fitted to keep for the day its needed for the rear should the above be an option on this car ?
  • 2 months later...
