so i have been using this for some yrs to great effect, i have just done a back to back from staffs to weston 140 miles ...there 52.7 mpg.
added zx1 from Halfords as i was setting back got 55.3 ....i know its only 3mpg but at 10 quid a gallon it all helps
added zx1 from halfords as i was setting back got 55.3 ....i know its only 3mpg but at 10 quid a gallon it all helps
Did you use your gold card and save even more 🤔😎
Just be careful.
It's not that long ago since someone here had problems after adding 'upper cylinder lube' and admittedly, his problems may have arisen from the fact that he put too much in, but the point is, these engines are some of the most finely engineered machines you'll ever see and will happily run to 200k, even 300k miles and beyond, without any extra sort of additive or lubrication.
If it ain't broke, don't fix it :thumbsup:
I've been using ZX1 for over 3 decades. You only use it once and that's when you first get the car.
How long had you had the car before you added ZX1?
On 7/2/2022 at 11:12 AM, Herbie said:
Just be careful.
I must admit, I've been tempted, but agree with "If it ain't broke, don't fix it", and that hopefully regular oil changes will keep it "unbroke".
Would possibly consider this, or something similar, if I had problems though.
yes they are covering their back like domestos says dont drink it .
this is my 3rd lexus hybid with zx1 and no issues .it is NOT  an additive it clings to the metal surface similar to magnatec
