NX space saver options?
I want to get a space saver / spare wheel for some longer distance touring....(had bad experiences with the useless kits supplied).  There's no Lexus Uk / dealer option. Has anyone found a solution or got a suggestion?
I recently bought one of these from Carnoisseur.They will sell you a kit minus the jack etc.
I haven't had to use it "in anger" yet,but have tried it on the front wheel of my RC as I was concerned about clearance on the large disc and caliper.It does fit and Carnoisseur were extremely knowledgeable and helpful.The wheel arrived at 8.30 next morning.
55 minutes ago, NemesisUK said:
Fortunately, mine came with a SpaceSaver.  But this does seem to be a very comprehensive and good value piece of kit.
The only reason I would use the injectable kit is if I was physically incapable of changing the wheel or the circumstances made it dangerous or impossible.  I suppose the only remaining problem is fixing the SS securely in the boot..
The wheel comes in a bag and lies flat in the boot.,It does take up a fair bit of space,but for my usage of the car, it's fine.It hasn't slid around or rattled.
1 hour ago, NemesisUK said:
This 18 inch wheel is for NX 2014 onwards so are you sure it will fit the new models from 2022? I would have thought that the bolt specs could be different.
I also note that there is no 20 inch version.
Buyer beware!
Give Carnoisseur a ring,ask for Patrick,they are very knowledgeable and helpful.They will need your tyre and wheel size to advise.A great company to do business with..a pleasant change these days.
