Carista on deal from Amazon £25
Ordered the Carista ODB2 Device from  amazon £25 using a youtubers discount code 'NOTAGURU25' worked out as £18.75
It has one month free trial subject to cancelling so you dont get charged monthly fee.
Unlocked a few features:
- Remote press windows up/down
- Blinker sound for indicatorss
- Seat belt chime off
- Walk home lights extended from 30 seconds-90
Etc
Also done the diagnostic check no errors, handy piece of kit. I recommend it  im sure others have used it before on this forum.
CARISTA OBD2 Bluetooth Adapter and App: Diagnostics, Customizations, Service Procedures and Live Data for your VW, Audi, SEAT, Skoda, Nissan, Infiniti, Toyota, Lexus, BMW, Mini https://amzn.eu/d/hzJAAEh
24 minutes ago, Gaurav Bhandari said:
Hey, Quick one,
Does it break warranty in any shape or form? Also, my car does not have window up/down feature, still it will be able to support?
Dont see why it would break your warranty your not tampering with the car as such to drive any negative defects. Your simply unlocking features pre-installed on the car from the manufacturer. Certain features are disabled as they are optional.
It does not allow alteration/ modifications to the drivetrain, engine or hybrid system if anything it will tell you theres a fault go to a dealer to get the work undertaken whilst your in the warranty period. (Just my view on it anyway)
Even the carcarenut recommends it..
I have the blue driver and sent email to them asking what it would do on my Lexus, this is the reply although I haven’t tried it yet ,I know it’s American but they shipped to me in uk and no subscription, not sure if same, better or worse.
Dell
Your IS will support all standard features:
   - Reading and Clearing OBDII Engine Codes
   - Smog/Inspection Status
   - Live Sensor Data
   - Mode 6
   - Freeze Frame
   - MIL Status
Additionally your vehicle supports reading/clearing diagnostic codes from the following enhanced systems:
       - ECM
       - Starting Control
   Transmission and Drivetrain
       - PCM
       - Transmission
   ABS and Brakes
       - ABS
   Airbags and Restraints
       - Airbag
       - Occupant Detection
   Tire Pressure
       - TPMS
   4WD/AWD
       - 4WD
   Doors and Windows
       - BCM
       - Door Motor - Driver
       - Door Motor - Passenger
       - Door Motor - Rear Left
       - Door Motor - Rear Right
       - Power Roof
       - Master Switch
   Battery and Power
       - Power Source Control
   Driver Assist and Active Safety
       - Adaptive Cruise Control
       - Pre-Collision 2
       - Parking Assistance
       - Camera - Forward
       - Lane Assist
       - Blind Spot Monitor Master
       - Blind Spot Monitor Slave
   Driver Information and Control
       - Instrument Panel
       - Remote Starter
   Entertainment and Navigation
       - Navigation System
   Heat and Air Conditioning
       - A/C
   Lights
       - Adaptive Front Lighting
   Premium Vehicle Options
       - Active Sound Control
   Seats and Mirrors
       - Mirror - Driver
       - Mirror - Passenger
       - Seat - Driver
   Security and Keyless Entry
       - Smart Key
   Vehicle Control and Suspension
       - Power Steering
       - Electronic Suspension
       - Steering Column
Your vehicle will also display the following live sensor data:
  - Smog Test (Inspection Monitor) Results
  - Fuel System Status
  - Calculated Engine Load Value
  - Engine Coolant Temperature
  - Short Term Fuel Trim - Bank 1
  - Long Term Fuel Trim - Bank 1
  - Intake Manifold Absolute Pressure
  - Engine RPM
  - Vehicle Speed
  - Spark Timing Advance - Cylinder 1
  - Intake Air Temperature
  - Absolute Throttle Position
  - O2 Sensor Location Map
  - O2 Sensor Voltage and Fuel Trim - Bank 1 Sensor 1
  - O2 Sensor Voltage and Fuel Trim - Bank 1 Sensor 2
  - OBDII Standard Compliance Level
Here are the exact settings the Carista app allowed me to do on the IS300H F Sport under the customise option in the app. Should it provide any insight....
The following settings were available specifically to your vehicle using Carista:
Dings & Warnings:
Seat belt warning ding (driver)
      ENABLED / *DISABLED*
Seat belt warning ding (front passenger)
Seat belt warning ding (rear passengers)
Ding when key is left in the car
      *ENABLED* / DISABLED
Ding when headlights are left on
      *YES* / NO
Remote low Battery warning
      *ON* / OFF
Heater & A/C:
Auto-turn on A/C when AUTO button pressed (if needed)
      *YES* / NO
Auto-increase blower speed when front defroster is on
      *YES* / NO
Also blow to feet in "face" mode
      *YES* / NO
Ambient temperature calibration
      -3°C / -2°C / -1°C / *NORMAL* / +1°C / +2°C / +3°C
Fan speed reaches its target…
      SLOWLY / *NORMALLY* / FAST
A/C ECO mode
A/C compressor noise reduction
Instruments: Displays & Nav:
Instrument lights dimming sensitivity
      DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST
Instrument lights restoring sensitivity
Engine start indicator
      *ON* / OFF
Display odometer after ignition is turned off for…
      *30 SECONDS* / 1 MINUTE / 10 MINUTES / OFF
Lights: Automatic:
Auto headlights activation threshold
Lights: Exterior:
Turn signal click volume
      LOW / MEDIUM / *HIGH*
Exterior light control
Coming-home lights duration
      30 SECONDS / 60 SECONDS / *90 SECONDS* / 120 SECONDS
Turn on marker lights when vehicle is unlocked via remote
      *ON* / OFF
Turn on exterior footlight when smart key in range
      *YES* / NO
Turn on exterior footlight when doors unlocked via remote
      *YES* / NO
Turn on exterior footlight for…
      OFF / 7 SECONDS / 15 SECONDS / *30 SECONDS*
Lights: Interior:
Interior light control
Turn on interior lights when you shut off engine
      YES / *NO*
Turn on interior lights when you unlock doors
      *YES* / NO
Turn on interior lights when smart key in range
      *YES* / NO
Dim interior lights after…
Interior lights linked to footlight
      *YES* / NO
Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
      YES / *NO*
Locking: Automatic:
Wireless door locking
Auto-lock doors when moving
      ON / *OFF*
Lock doors when shifting into gear
      ON / *OFF*
Unlock doors when shifting into park (P)
      ON / *OFF*
Unlock all doors when driver's door is opened
      *ON* / OFF
Re-lock doors automatically if you unlock, but don't open a door within…
      30 SECONDS / *60 SECONDS* / 120 SECONDS
Locking: Beep & Blink:
Blink turn signals when locking/unlocking with remote
      *YES* / NO
Locking: Doors & Alarm:
Unlock doors via remote
      DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
Unlock doors via physical key
Unlock doors via smart key (door handle button)
Warn (beep) when door can't be locked because it's still open
      *YES* / NO
Warn (beep) when a window is still open when locking doors
      *YES* / NO
Warn (beep) when sunroof is still open when locking doors
      *YES* / NO
Disarm the alarm when unlocking with key from door lock
      *YES* / NO
Intrusion sensor when window is opened
      YES / *NO*
Locking: Smart Key:
Stop monitoring for car key signal after…
      1 days
After locking with smart key, don't allow re-opening within…
      0.5 SECONDS / 1.5 SECONDS / *2.5 SECONDS* / 5 SECONDS
Smart key location to start car
      FRONT SEATS / *ANYWHERE IN VEHICLE*
Unlock trunk when smart key in range
      *YES* / NO
Mirrors:
Lower passenger-side mirror when in reverse gear
Dings & Warnings:
      *YES* / NO
Remote low battery warning
      *ON* / OFF
Heater & A/C:
      *YES* / NO
      *YES* / NO
      *YES* / NO
A/C ECO mode
      *ON* / OFF
Lights: Automatic:
Lights: Exterior:
      *ON* / OFF
      *YES* / NO
      *YES* / NO
Lights: Interior:
      YES / *NO*
      *YES* / NO
      *YES* / NO
      *YES* / NO
      YES / *NO*
Locking: Automatic:
      ON / *OFF*
      ON / *OFF*
      ON / *OFF*
      *ON* / OFF
      *YES* / NO
      *YES* / NO
      *YES* / NO
      *YES* / NO
      *YES* / NO
      YES / *NO*
Locking: Smart Key:
      1 days
      *YES* / NO
Mirrors:
Nothing in the list to say "open/close windows using key fob?
Dings & Warnings:
      *YES* / NO
      *ON* / OFF
Heater & A/C:
      *YES* / NO
      *YES* / NO
      *YES* / NO
A/C ECO mode
      *ON* / OFF
Lights: Automatic:
Lights: Exterior:
      *ON* / OFF
      *YES* / NO
      *YES* / NO
Lights: Interior:
      YES / *NO*
      *YES* / NO
      *YES* / NO
      *YES* / NO
      YES / *NO*
Locking: Automatic:
      ON / *OFF*
      ON / *OFF*
      ON / *OFF*
      *ON* / OFF
      *YES* / NO
      *YES* / NO
      *YES* / NO
      *YES* / NO
      *YES* / NO
      YES / *NO*
Locking: Smart Key:
      1 days
      *YES* / NO
Mirrors:
Lowering mirror when in reverse seems super useful to me. Has anyone tried it to see if it works? Or is it model specific? Id gladly pay to have that.
I have this on my 2013 F-Sport with memory seats. Very useful to me. It was enabled by default, I used no device like Carista to enable it.
Got it. It might be trim level specific then. My executive doesnt do it and i have manual seats. Its something i really use a lot to avoid curbing the wheels but since i do it manually now i keep forgetting to correct my mirror when driving its such an annoyance.
Mines does it.. I have F-sport with memory seat also
