Sign in to follow this
stevebish
Windscreen Washer Jets
OK, guys,
Hopefully this will be a quickie!
I've got my new washer jets and want to change them without damaging the old ones while removing them. Whats the best way to go about it?
It's a very small hole to get into and I can't seem to release the claws very easily!
Any help will be appreciated!
All sorted!
Has anyone else changed from the triple jets to the fan jets? They seem to be directed to the bottom of the screen, do you have any problems at higher speeds? Are they adjustable at all?
The ones that are on the latest models...?!
They produce a 'fan' style spray instead of two/three squirts!
Hmmmm....
I've got one of these....
I ordered it from Notts and it took 4 weeks to arrive and there was only one - my fault (forgot to say 2 when I gave them the part number) but it's taking a while for the 2nd one to turn up - would you say they're better than the originals?
One of the reasons I wanted to upgrade was that I've got **** loads of wax stuck in my old ones...
I'd say it was a classy little mod, but cannot comment on it's effectiveness on motorways yet!
Get 'em fitted Aido!
Dammit.. no Royal Sapphire Blue.. looks like a set of white ones & paint them.
Thanks for the info Aido
Royal Saphir blue should be -J0 (if your colorcode is 8N6)
Sometimes it is called grayish blue met?
So you go for 85381-53070-J0
But check the codes before ordering.
Hope this helps.
;) B) get the dark blue ones, I did coz I got royal saphire lex, thought I would have to spray them. Put them on and you can't tell.
DARK BLUE (8P4) 85381-53070-J1
:winky:
Yeap much better gives the screen a good soaking from left to right B)
