Eight Speakers?
rear speakers are double units  not 2 way but 2 speakers on top of each other.
plenty of posts about this can be found using the search button, which will give u more info
How does that work, one on top of the other? Don't suppose there is a picture of such a setup is there?
Its pretty cunning if you ask me...
The fronts are 2-way components.. So thats 4 speakers
The rear 6x9s are 2-ways.. They classed that as total of 4 speakers again :duh:
Thats how they quote 8 speaker system.
at the front u have a tweeter and the speaker in the door so that is 4 in the front total.
the 2 speakers at the rear are not 2 way but are 2 seperate speakers each so that is a total of 4
that is where u get the 8 from.
But they aren't 2 way, they are 2 on top of each other. How does that work?
a frame that hold 2 speakers by any chance ;)
do u mean how is the set up or how does one speaker slightly above the other work?
I got the idea that they were 6*9's on the parcel shelf yeah? If so and there are two at either side, and on top of each other, how are they mounted? And incidentally, how does not block out sound from the speaker underneath?
Apologies for my insolence
