Red Line
Today on the way back from work I was overtaking a car and I had the music up quite loud so could not hear the engine. I think I red lined the revs, however the only way I could tell was because all power fell away from the car (I could no longer accelerate).
Does anyone know if the Lexus has an automatic function to shut down any further acceleration if in the red line area? :blink: Or what might have happened? :ph34r:
yes, the IS has a 'rev limiter', so if you reach the maximum reccomended revs, the engine cuts back (not out as other cars do)..
You wont of done any damage, as thats what its there for... and in all honesty, I've hit the limiter a few times... its the problem having peak power at 6250rpm and the redline at 6500 really...
well - the redline is there to warn you that at that point damage will be done to the engine.
Of course, as you have found, you dont always notice the redline when overtaking etc.
So they invented limiters, which, in a nutshell, dont allow the revs to get to the point where they will damage the engine.
On top of this, the limiter will have a 'buffer zone', so more than likely, you could rev the engine 250rpm's higher than the limiter without doing any damage.
Now of course, i'm not saying over-revving the car wont do ANY damage - if you do it when the engine is cold, that can increase the rate of wear, and if your bouncing off the limiter in every gear, that can also reduce an engines life - but every once in a while, that will have no negative effects on the engine...
I had an Audi TT prior to the Lexus and when I took this car in for the service they could tell if my alarm had been set off?
thats probably because the alarm horn being active melted half the ECU electronics :lol::lol:
What does it matter if Lexus see you hit max revs? it cant invalidate your warranty!
they could have just a basic fault alarm that remains in the memory until it is cleared. Just have various functions.
We have taht on trains, and with 48 inputs, then speed on top of that no for that 128MB remembers about 3 days. So for a car to do same would need a huuge memory on board
