Downloading Music
mudzs
Hello its Mrs Mudzs here - Tony told me you lot know everything so here is my problem:-
I want to make a music CD and have installed Limewire. Every time I do a search nearly all the files listed are MP3. Some of the ones that are not MP3 are locked. Is there a more appropriate program to use? This is driving me mad!
I use Shareaza :winky:
Hi Mrs M,
Welcome :D
I don't understand why you don't want MP3s??
You just download the ones you want, then use a CD burning application such as Nero to make an audio CD. Nero will automatically convert your MP3s into an Audio CD compatible format.
It really is as easy as that! :D (Unless I have misunderstood :unsure: )
THanks guys. Its just that I have downloaded tons of MP3 files and tried burn to CD (not using Nero) but wouldn't play. Must have done something wrong I am going to try Nero.
Thanks again, Mrs M.
You probably tried to create a data CD - which is just a CD with MP3s on it. These won't work. You need to select the AUDIO CD option.....then they should work great!
Good luck :D
