Hi all,
My rear door sensors, just stopped working! Door open indicator on dash not showing either as open and if i unlock the car and open both rear doors, the system relocks all doors after 30 seconds as if I hadn't open a door.
If it was only the one I would suspect the sensor, but both :duh:
Could this be a fuse? or summit else?
If lock is suspect how difficult to remove/check?
Any help would be much appreciated
Are you sure they stopped working at the same time?
Hmmmm....... possibly not but they were working when I bought the car 3 weeks ago (I checked all doors) & now their not, so I assumed................
  • 10 months later...
Hi I have exactly the same problem, doors lock themselves after 30 seconds, no light comes on the dash to say the rear doors are open, no interior light when rear doors open. Did you manage to find out what the problem was?
