Aristo V3.0
the_wiley
276ish bhp, somewhere near that for torque level in llbs/ft
0-60 guessing around 6ish
top speed, limited to 112mph, unlimited, 150+ mph
I average around 16mpg, but I only drive it about once a week if that, and so I tend to enjoy myself :D
I'm about to change the O2 sensor, so that should make a bit of difference.
The Engine spec on my car is factory standard so the figures are what Ahhhh__Aristo says.
I drive my car everyday,around town i get about 20mpg and on a run maybe nearly 30mpg if its driven steady :)
If you boot it then your going tobe getting into the low teens mpg.
The more mods done to the car(more power) the lower your mpg will be.
Chips..
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
