Is220d Headlight Cluster
It's do-able, if you've got the skill (and the bottle! :blink: )
You need to remove the headlight cluster, and heat it in a medium warm oven at 5 min intervals until the silicone glue that fixes the lens to the cluster goes soft. You can then peel away the lens and get to remove the orange part.
While you're at it you may as well spray the inside of the clusters a nice metallic black or similar to get the full effect.
To put them back together use a clear silicone sealant (like the stuff you seal the bath with).
