Tyres
Read through some of the comments in the Wheels & Tyres section.
See Here
I've recently switched from Bridgestones to Goodyear F1's and I'm very impressed with their performance.
They're well 'ard.
Great in both the wet and the dry.
But they're noisier than the bridgestone's.
I too have just had 4 spanking F1's put on mine to replace kumho's.
Lucky I did, NSF tyre had a slit that was allowing the tread apttern to come away from the tyre . This was on the inside face of the tyre therefore could not be seeen normally. The tread had lifted so much you could slide your hand inbetween!
Scary .
F1's seem good so far, not tried them in the wet, only done 300 miles since wednesday on them.
My advice, DON'T scrimp on tyres.
Yup, F1's are the biz. :hocus-pokus:
And not just the performance, even the tread pattern looks good. B)
And dont' forget to park the car with the wheels turned out, just to show 'em off!! B)
<------ Check my Avatar :whistling:
I had a Nissan 300zx before the IS and all 4 corners replaced with F1's. Did around 10k miles a year and found the rears wore down within that time. Very good tyres with lots of grip otherwise. Of course it could have been my fault lighting them up when i could !!!
