Wheel Offset Question
Twisted Minis
Take off the wheel and look at inside face , example... ET50
I know how to measure backspacing. The problem is that I don't have the wheels to measure off of. I was hoping someone would know. I want to put them on my Toyota truck, and have the centers machined to fit my hub. I just need to know if they will fit.
I was under the impression that the TOYOTA HILUX were 6 stud ?
TOYOTA HILUX
PCD 6 X 139
OFF SET 10 - 20
C/BORE 106
RX300
PCD 5 X 114.3
OFF SET 38 - 45
C/BORE 60.1
I can't see that this can be done?
Not impossible (conversion kit etc.) but probably not ecconomical.
The 4WD is a 6 lug, yes, but I have a 2WD truck.
This is what they will go on.
My bolt pattern is 5 on 114.3, and on an 18x7.5 wheel I need a +45 offset to fit like the wheels I have now. So if the information you provided is the correct backspacing for the RX300 or 330, then they should fit. My c/bore is 110 or so. This is what has to be machined on the Lexus wheels.
I just really like the look of the stock 18x7 wheels.
I just wanted some insurance that they would tuck inside my fenders before I went and spent money on a new set.
Is the information you posted for that wheel? Or is it for that model in general. Either way, and 18x7 with that offset should fit just fine.
Thank you.
  • 4 weeks later...
