Squeeling Rx300
refLEX
I have a MK1 RX300SE that has started squeeling when starting from cold, the noise is definately a belt slipping but i dont know what belt or more so how to adjust it. It does seem to be less of a problem if the A/C is switched off on start up so i am thinking that it must be the belt that also drives the AC pump?
Any help and advice would be most apreciated please.
Thanx
I have seen "mechanics" squirt some WD40 onto the belt as the engine is ticking over to stop the squealing, shut the noise up instantly. Im not sure if this is a good idea or not, So I would seek some better advise before going ahead with it.
Thanx Brettster! I have also just had a look at your excellent 360 site and was wondering if you could advise where i might be able to buy "back ups" of games i already own :-) for my modded 360?
many thanx
