Fitment
  • 1 year later...
but its the foglight im worried about.you are very sure is300 foglight will fit is200?
Yes mate the IS300 foglight will fit the IS200 as its the same fittings (unless its a sportcross version) If anything the wiring plug might be different if you get a foglight from a newer model as they use a different bulb system :)
