Please Help Part Info Needed
donkammy
Ok guys,
need abit of info on a part it is where the brake bolts into on the front passanger side wheel
what has happened is, my bolt come loose on this sort of housing and it has cross threaded and smashed the bolt, i need this part if anyone can help me.
it is not the brake caliper, but the brake caliper bolts onto this housing.
i believe it has two 12mm bolts (think that is the size) going into the housing
many thanks
Donkammy
If its just bolts, bring in another one (from the other side) and go into a hardware store, they would have plenty of the same size :)
I believe he wants the caliper carrier not the bolt????
Ok guys,
many thanks
Donkammy
Got the caliper diagram if any help most Toyota dealers should supply the bolt/caliper carrier if required?
Well thats where i bought the caiper from last week took a few days to arive from Japan.We should be able to track/find a part number?
twin_piston_type1altezza.jpg :winky:
