High Grade Wet And Dray Sandpaper - Source?
Hi.
Does anyone know where you can get hold of some high grade wet n dry sandpaper?
Grade rating of at least P2000.
Halfrauds only go up to P1600 iirc.
No luck in DIY stores, Wilkinson...
D.
Hi.
D.
Turtles in Croydon should have some
or any decent motor factors shop
Hi.
D.
Hmmm. Cheers Barry.
Just called them but they only go up to 1200...
Any more for any more?
:crybaby:
you can soften grades down by using soap or washing up liquid with them
keeps your fingers soft and clean as well :lol:
For real? I didn't know that.
Is that the secret to your ever youthfull looks Barry? :winky:
certainly is, i dont look bad for 82 do i :P
Look on eBay mate. bought some a while ago from a buyer on there and some 3000 grade as well :crying::whistling: Make sure its the proper waterproof stuff as well otherwise it will fall to bits! i know its obvious but some of them are not and will not work well when put with water, i tend to just use the officail 3M stuff!!!!
Jason :P
