Brake Fluid Amount
I'm planning to upgrae my brakes and i'm gonna change the fluid from the DOT3 standard up to DOT5.1,
To do this i've got to drain the whole system and fill it again so i need to know how much fluid i need, Anybody know?
I've looked in the owners manual and it just says DOT3 no amount is specified.
You may be better off getting more, coz you will have to flush/pump the old stuff out :D
just make 10000000% sure it is DOT 5.1 AND NOT DOT5 as you can not mix DOT5 with anything else as it requires different seals and within a day the fluid will be running out of the car.
a few litres should be more than enough - remember to drain/bleed the clutch also as i assume you have the clutch and brake linked together?
  • 1 year later...
clutch fluid and brake fluid are not linked on the 200.two seperate fluid bottles.
see pic.(thank god i just cleaned the engine bay)
see top left two seperate bottles.
Yeah, this is an old thread that I tacked onto because I was asking exactly the same question. I think that the references to them being joined (in the very old postings !) are in relation to using the TTE airbox with the supercharger kit, where I think you have to do away with the clutch reservoir to make the airbox fit.
I'm still interesting in knowing how much brake fluid is needed though !
to flush the system and renew all prob about 3lrt max dude.when i done asi's brake lines i renewed his brake fluid i used just over 2 lrts.
thanks ormi for doing the work
no problem dude glad to be of service.
it was also nice to meet a fellow member. B)
let me know once you get the pollen filter
thanks
polin filter in matey.
