Will Is250 17" Alloys Fit An Is200
Noel
I have the IS250 Sport 18" rims on my IS200.
Same stud pattern, slot straight on.
These required a very minor arch mod due to the extra ICE Boot Build weight carried
and they are running 255/40x18 Dunlop Sports Maxx. These should fit fine on a
non lowered S or SE. I'd suggest the Sport model may require a minor arch roll or cut.
The 17" fit without any mods. I have the IS200 Sport and IS250 SE-L and have the 17" 250 wheels on the 200 Sport...no probs.
yes they will mate.have them fitted to my 99 is.had to grind a little off the suspension arm as there is a small lug type thing which just touched the rim.215 on front and 225 on rear.
Very odd :huh: as my 18" rims only touched very slightly on outer wheelarch because of the weight of my I.C.E. boot build.
I'm running 225/40x18 Front, 255/40x18 rear.
Maybe the offset of my wheels is different ??
Front: 18" x 8" 45mm offset , Rear: 18" x 8.5" 50mm offset
tiz lowered 30mm.they are 17inch rims of is250.had no probs with catching the arches.maybe the 250 sport has the 18s fitted.note.the wheel centers for them were £12 each.OUCH
I had to grind the little lug off the suspension arms as the 17" rims just touched on the rim edge...just thought I was unlucky, but the 18" would actually clear the lug so no problem at all to fit the 18".
sorry now i'm a little confused? :huh:
17" need something ground down to fit?
18" go straight on?
:unsure:
Going on what Tango says the 18" rims clear the lug by virtue of their greater diameter,
(they actually go outside & around the lug)
The seventeens are smaller diameter and are tight enough to just catch the lug on the inner rim edge.
Hope that makes sense :D
18" go straight on?
:unsure:
Wozza..spot on. I only found out when I spun the wheel and could hear the slight rubbing noise. There's very little contact and clearance could be made with a hand file, but I used a junior hacksaw to remove the majority of the lug and smoothed it off with a file afterwards...it was quicker.
18" go straight on?
:unsure:
would you have a pic of this "lug" was it there for a reason?
Is this lug on all hubs or just the rears?
cheers
18" go straight on?
:unsure:
cheers
Not on the hubs, it's just on the vertical front suspension arms, and I would suggest it's only there to assist in the manufacture of the arm, not for any functional use or strength requirement.
