Squeaky Gear Lever Gator
ummmmmm - might be a problem with this, the inside of the gaiter is suede - so that isnt going to make the squeaking noise!!!!! you will find it is because of the leather on the outside of the gaiter rubbing together that is making the sound.
I suggest getting some " leather feed" cream from a proper shoe shop ( no its not polish) rub that on leave it to soak in and the problem should stop, or you could always just loosen the gear knob and twist the gaiter slightly, this can also stop the squeak.
