Does Anyone Know How To Reset The Oil Maintenance Light?
it's a big flasing yellow light on top of a orange van that parks in front after you don't maintain the oil
B I N G O - Thanks to Peco84
Just keep the odometer button pressed in & press start without depressing the clutch pedal. The odometer will then show a series of dashes & start counting down, when the dashes disappear it's reset...
Thats it while the ignition is in ACC mode without engine Running ( As mentioned in the owners manual)
Handy Toilet reading info :winky:
Regards
Matt
By the way why do you need an Oil check gauge on the Diesel As this is the first diesel i have owned
why is it there ???
Regards
Matt
why is it there ???
  • 7 years later...
Had the same problem, reset via holding odometer & pushing start button with depressing clutch, worked a treat, many thanks
