any information please is it difficult to fit a new water pump . is it too complicated.my ls 400 is a 1990 model thanks
Hi
See here for DIY replacement, the rest of this site is excellent, you won't be going to bed before midnight tonight!!!!
http://www.lexls.com/tutorials/engine/timingbelt.html
Good Luck and welcome to the LOC
Pete
Hi
Pete
HI PETE CAN THE WATER PUMP BE DONE SEPERATE OR IS THE TIMING BELT INCORPORATED THANKS HAMMERS41 (GIL) THANKS FOR YOUR HELP
The water pump is driven by the cam belt so this means removing the cambelt to fit the pump plus the strip down is the same to get to the water pump.
It is best to replace both the belt and pump at the same time to avoid 2 major projects instead of one.
THANKS FOR UR HELP STEVE GIL
If you're going that far then do everything in that area while in there. All day job if not done before. Can't remember how much I paied for the water pump from a auto parts place in UK, But it was around £35. There's a thread of mine stating LS400's servicing costs which listed the prices and where I got the parts from somewhere on this forum.
