Steam Cleaning
ant1
hi all,after having my lexus is200 sport serviced it was suggested that maybe i should steam clean the engine although its only dusty not oily etc is this a wise thing to do and if so what precautions should be taken,otherwise ill simply clean it by hand,thanks in advance
cleaning it by hand is a safer option IMO
I agree :)
i also agree. if its only dust just use a damp cloth or cleaning wipes then use detail products to shine any trim :)
I use spray tyre foam on mine matey and then wipe it over,
Does a good job and not expensive as some of the guys who went to JAE saw this year, when i was cleaning there engines for them :D
If you spray it on a warm engine and wipe of the residue after a few minutes it will dry to a nice shine and remove quite a bit of the dirt :)
I'd never have an engine steam cleaned. There's too much that could go wrong. Unless it's a show car, I think I'd be very hesitant about deep cleaning anything in the engine - a quick once over with a damp cloth and some foam spray will probably suffice. Also buyers are always advised to be suspicious of overly clean engines - worth considering if you're planning to sell the car.
