Inputing Telephone No's
As I'm a new owner of an LS430 please excuse me if I've missed something obvious.
I can get my phone to work with the car's handsfree to receive calls, but an unable to transfer across to names and numbers.
Is there any way you can manually add them?
Andrew
Hi Andrew
This is how
Turn on Ignition & start the car.1-Press option button on left side.2 Press information button on screen.3-Second item along top is telephone press it.4-fourth box down from left is settings press it.5-scroll down left hand side 2nd down on screen is transfer phone data next to that is a box press start.Press it.6-Screen comes up with transfer phone book data select transfer method overwrite or add.If you press overwrite screen will come up with please transmit phone book from telephone.WAIT about 20 seconds untill the cancel unhighlighted button highlights.Make sure your phone is near the gearstick when you do this.7-Then take your phone & go into phone contacts then go options & then more then advanced,in their you will find send all contacts.Click & send via Bluetooth & wait.Press o.k on screen all done.
Many thanks for your detailed instructions.
I've got it to work, almost.
It takes over all of the numbers, but not the names :rolleyes:
I presume that this is due to some incompatibility between the phone and the system.
It does mean however I can take a call, so it's better than nothing
Andrew
Andrew
You could be right on that one.I have the Sony erricson & this transfers the names & numbers.
Hi Andrew
This is how
Turn on Ignition & start the car.1-Press option button on left side.2 Press information button on screen.3-Second item along top is telephone press it.4-fourth box down from left is settings press it.5-scroll down left hand side 2nd down on screen is transfer phone data next to that is a box press start.Press it.6-Screen comes up with transfer phone book data select transfer method overwrite or add.If you press overwrite screen will come up with please transmit phone book from telephone.WAIT about 20 seconds untill the cancel unhighlighted button highlights.Make sure your phone is near the gearstick when you do this.7-Then take your phone & go into phone contacts then go options & then more then advanced,in their you will find send all contacts.Click & send via bluetooth & wait.Press o.k on screen all done.
Blimey that's complicated I think I'll use a phone box! :whistling:
Thanks for all your help lads.
The good old Sony Ericsson T630 has been brought out of retirement, and has done the decent thing.
Working a treat now :)
Andrew
