I have just bought a IS250, on driving home I thought I would put the stereo on, switched it on, it all lights up but there's no sound, the numbers go up and down but no sound still. It's the one without the sat-nav. Am I doing something wrong? Is there any fuses I can check please.
im not trying to teach you how to suck eggs i hope but have you pressed in the volume button for andio on/audio off? i often do this by accident. also if you play a song that realy tests the limits of the stereo (which takes some doing! ) it cuts out as the amp "protects its self" also known as "clipping" but turning the ignition off and then back on resets this.
  • 2 months later...
Has any one else had this problem as on the way home tonight my stereo went silent :tsktsk: power still on, reads discs ok, radio stations there but no sound?
checked to see if a fuse has gone but think its possibly the amp. :crybaby:
phone call to lexus bham in the morning but just seeing if anyone else has had this happen :whistling:
