Squeeky Power Steering
Andy-R
Just been out to move the car and noticed the power steering squeeking on full lock, if I eased back a little it stopped, could this just be the cold and need a spray with WD? or is it worth changing the fluid before it gets worse, it's never done it before :huh:
After I had my belts replaced my car squeeked a lot when it was cold, even though I only turned the wheel slightly. However, I had the car serviced last friday, so I told the mechanics about the problem. I turned out to be easily solved. They just tightened the belts and the noise was gone :)
Cheers
