Clutch?
hi, i changed my clutch around 5 months ago, has been working fine until recently. it goes into gear perfectly n i can pull of perfectly. pedal does feel a bit soft n spongey. but wen i put my foot down it seems lyk nothing happens! revs build up slowly n seems like the car has no power! someone please help shed some light on this! thanx
  • 7 months later...
i would bleed the clutch pedal line first
Sorry to bring up an old post.
How do you bleed the clutch line?
Cheers.
pretty much the same way as you do with brakes
there will be a bleed nipple (not sure where tbh )
push clutch pedal as you release the nipple, then tighten when pedal is fully depressed
Cheers.
Cheers Barry, bit hard to that as the pedal goes straight to the floor :(
Found the bleed nipple on the release cylinder bolted to gearbox.
Cheers as well to Steviewevie for the pics.
Location of Clutch Release Cylinder
Breakdown of Clutch Release Cylinder
Cheers.
why a bit hard ??
Cheers.
why a bit hard ??
Sorry, I meant 'push clutch pedal as you release the nipple' as there is nothing to push. We'll see when the car is jacked up. Fingers crossed as we're supposed to driving to Germany tomorrow.
Cheers.
why a bit hard ??
no there will not be any pressure but it still forces the fluid or air through
