Altezza Exhaust
dlocko
hi guys
just wanted to know if any of you know where i can get a Kazama exhaust i heard them on you tube and they sound exactly what im looking for.(deepish,with some rasp)
is there any other exhausts i should consider,the high power hks silent is a bit too quite for what im looking for and i do not want a weld on back box.
i currently own a altezza Rs200 beams 5a/t
thanks for your advice
Dan
as far as i know it looks exactly like this
The Kazama was based off the original HKS Hiper - if you hit a brick wall then one option you may want to look at is importing one of the Hipers from the USA - the only difference is the tailpipe would stick out an extra inch or two at the back I believe.
