Is 300 Hid Fog Lights?
Quick question.
I have been meaning to do this for a while now, but not got around to it, I was hoping for guidance, on my IS 300 the Head Lights are Ice White HID but the fog lights are yellow and it looks odd, does anyone know where I can buy some Ice White HID fog lights for the IS 300? And how much they will cost to buy and fit etc?
As always thanks for your help.
Quick question.
You can buy ice white or blue bulbs on eBay for under a tenner much cheaper than going full HID, nice and bright also
Is it just the bulbs your after matey? or have you got the oem Yellow fog lights themselves? :unsure:
I'll have to double check, but I believe I have the OEM Yellow fog lights themselves.
If you have mate you'll probably have to change them for a set of clear ones as they have a yellow filter behind the lenses?
Or you could probably break them down and remove the filter using the oven trick to remove the lense. But not sure if the lense itself is painted or has a plastic cover to make them yellow :unsure:
