Skinny Wheel Nuts ?
abbott
Hi this morning i went out to fit my new alloys and i noticed there is no way possible the studs are going to go in the hole to fit wheels to the hub.
So i believe i need something a little skinnier , can anyone help me with my quest is there something specific i have to ask for or is it simply skinny wheelnuts ?
thanks in advance im dying to fit my new rims .........
:whistling:
:whistling:
so is it studs or nuts you are after - i doubt very much the studs are too big for the wheel
:whistling:
:tomato: i believe you are correct its nuts ! :tomato:
I assume your after nuts.
Theres loads on Ebay, your wanting m12x1.5 i believe
i have found these skinny wheel nuts i believe these could be the answer to my problems ...
thanks for the help once again guys , im DYING to get my ultralites fitted !
Hmmmmm i seem to have missed those ones
nice one aztec !
There are quite a few sets on there mate so you might even find them a bit cheeper if you search for (wheel nuts 12x1.5) or (tuner nuts) or if you want a really good set look for the ultralite ones :)
nice one aztec !
I was looking at the ultralites but i think they are a little overkill for just now as these alloys are just make shift till i get the 20s that are in the pipeline for later on in the year . :winky:
(i have been spending a lot of time on US lex forums i am in love with 20s )
there the same as mine :winky:
take it they are sound then yeah ?
I use a similar tuner nut to those on my GS. Work a treat. Be careful though, some are not the "star" key type, but like an allen key. I had a cheap set like that and the allen key was a sh*te fit, so rounded off and the nuts had to be forcefully removed by other means. I now have a good quality set on. Just be careful with the cheap ones.
