Water In The Trun And Solution
Today I discovered 2-3 centimeters of water on one side of the trunk and humidity on the other side.
After drain and dry I found the cause in both cases, this piece of pipe is not in the building or is folded and does not work.
Check yours!
If you need a new section of pipe, B&Q have them Just use a size up to make a sleeved joint or try most garden centres in pond section.
Do they have B&Q's in Málaga?
LOL...
LOL...
:D
Well now I'm living in Barcelona, maybe here... :P
|okay well yours may be a seprate issue but i eventually found the water leeak in the misses car. it was coming in from under the rear window. I had it removed and loads of goo reapplied. Bin bone dru ever since.
There were a total of 4 leaks to deal with thou, 2 under the screen and 2 on the boot lip join
Anyway as I said boot is completely dry now for the last couple of months, i gave the boot a spray of silver wheel paint and it looks nice and sweet now
jules
had the same problem on mine, just removed the rubber grommet in the bottom of the well so the water just runs straight out... quick fix if you havent got a replacement pipe :D
  • 4 weeks later...
jules
:crybaby: I was wrong, I haven't found the solution, still water falls. At the moment I removed the caps and I will check again with your tips.
